What speed is my Hard Drive??
G
Guest
Guest
I just bought OEM Western Dig 20.5 gig HD 7200
I want to make sure I didn't get ripped off. On the HD I see the 20.5 but nothing about speed. Is there something I should look for??? Or would I be able to tell when I build my system??? Thanks
A part number should be on the drive. Is it 204BB? If not, than post the part number and I can give you some info on it.
find a specific drive model on the drive...
look for something like "WD200BB". If you that one, you are probably ok. If you see a model # ending with AA or AB, you might not be.
***Hey I run Intel... but let's get real***
Thanks guys! I'm at work right now and I don't have it with me. My invoice says WD205BA. I'll check it out when I get home. I went on WD Website and the 205BA is 7200. Hope the numbers match at home.
