Can anyone tell what the power consumption of an E2140 would be if overclocked to 3.2 (or 3) ghz? The EPS Calculator says it would go from 65 watts to 520! That's seems a bit OVER clocked to me.
Apart from that, do I also need a separate cooling unit? Can't I do without it? In summers, it is as hot as 48 degrees Celsius.
I was going to replace my 945G motherboard with a G31 or 41, to get rid of the CPU bottleneck towards the Sapphire 4870 I have.
Thanks
Thanks
