Hello. I am in dire need of help.
I just registered because I don't know where else to seek for help anymore. Reddit wasn't helpful at all and before I began this post, I did as much research as I could, followed some links and instructions from other Tom's Hardware topics that dealt with the same error. Nothing helped.
This post is literally my last resort because I am at a loss of what to do. I tried testing what I could from temperature, to memory, disk errors, updating BIOS, updating Windows, resetting, reverting updates, you name it. Everything seems to be working well. Not an error in sight.
For context, I've been getting the BSOD at random, with the whea_uncorrectable_error. Be it when playing games, watching YouTube, turning the PC on, watching a movie... anything. I then need to reboot it manually, because it often says that it cannot find a bootable device. Between the times of these random BSOD the laptop works normally, infact, as if nothing's wrong at all. One of the reddit users asked me to check for a minidump but strangely enough - there's none. No minidumps or anything.
Is there anything else I can do at all or am I just out of luck? I've had a comment mention a possible faulty SSD or possible need to reapply thermal paste, but again, it might not be it. This is the only laptop I own and gaming is my passion. I just want to know if I can save this in some way 'cause I don't think I can afford even a basic new pc nor even to repair this. I wish I could at least identify what could be causing this BSOD.
Below I will post the specs, if anything's missing please do tell:
OS: Windows 10 Home 64-bit (10.0, build 19043)
System manufacturer: Intel(R) client systems
System model: LAPQC71A
Processor: Intel (R) core(TM) i7-9750H, 2.60GHz (12 CPUs)
RAM: 16GBIntegrated
GPU: Intel(R) UHD graphics 630VRAM: 128MB
Dedicated GPU: NVIDIA GeForce GTX 1660Ti
VRAM: 5991MB
Storage: two 1TB SSDs, NVMe
Manufacturer: Cyberpower UK
---I should also mention that this laptop has no battery, because it ened up swelling and I had to remove it. No chance of replacing it.
Any help is greatly appreciated.
RAM: 16GBIntegrated
VRAM: 5991MB
