When cpu gives beep then what is the problem with cpu?
Roadrunner, the coyote's after you. Roadrunner, if he catches you, you're through!
Beep Beep!
CPU can't give a beep or a bleep because CPU ain't got no speaker. If you hear a bleep, it's probably coming from your case's speaker indicating a potential problem. You need to know what your motherboard brand and model is, and what the sequence of beeps, including whether they are short or long beeps or both and in what order, in order to determine what the beeps mean. Go to the website of your motherboard manufacturer, find the model of the motherboard, and then download and open the information manual for it, if you don't already have it in written form. Then, try to find what the sequence of those kind of beeps mean. Google is your friend.
Since your CPU "does not start", someone who knows what they're doing might want to "ground" themselves to remove static electricity and then remove the battery on the motherboard for 1 minute, then put it back in, in order to reset the motherboard bios to the default values, then try to restart the computer and see if it starts. If all this is too confusing, my advice is to find the most reputable, honest and cost effective computer repair store you can afford and take your cpu, er, your computer, there to be repaired if possible. Of course, your cpu, er, your computer might be unsalvageable. Next time, please give us some more specific information. Not all of us are telepathic unfortunately.
What kind of beep? Long or short? How many?
If a single short beep, that means the motherboard and CPU successfully passed the POST (POwerup Self Test). If you do not see anything on the monitor, either the monitor, cables, or video card is bad.
For any other beep pattern, check your motherboard manual.
Work systematically through our standard checklist and troubleshooting thread:
http://www.tomshardware.com/forum/261145-31-read-posting-boot-problems
I mean work through, not just read over it. We spent a lot of time on this. It should find most of the problems.
If not, continue.
I have tested the following beep patterns on Gigabyte, eVGA, and ECS motherboards. Other BIOS' may be different, but they all use a single short beep for a successful POST.
Breadboard - that will help isolate any kind of case problem you might have.
http://www.tomshardware.com/forum/262730-31-breadboarding
Breadboard with just motherboard, CPU & HSF, case speaker, and PSU.
Make sure you plug the CPU power cable in. The system will not boot without it.
I always breadboard a new build. It takes only a few minutes, and you know you are putting good parts in the case once you are finished.
You can turn on the PC by momentarily shorting the two pins that the case power switch goes to. You should hear a series of long, single beeps indicating memory problems. Silence indicates a problem with (in most likely order) the PSU, motherboard, or CPU. Remember, at this time, you do not have a graphics card installed so the load on your PSU will be reduced.
If no beeps:
Running fans and drives and motherboard LED's do not necessarily indicate a good PSU. In the absence of a single short beep, they also do not indicate that the system is booting.
At this point, you can sort of check the PSU. Try to borrow a known good PSU of around 550 - 600 watts. That will power just about any system with a single GPU. If you cannot do that, use a DMM to measure the voltages. Measure between the colored wires and either chassis ground or the black wires. Yellow wires should be 12 volts. Red wires: +5 volts, orange wires: +3.3 volts, blue wire : -12 volts, violet wire: 5 volts always on. Tolerances are +/- 5% except for the -12 volts which is +/- 10%.
The gray wire is really important. It should go from 0 to +5 volts when you turn the PSU on with the case switch. CPU needs this signal to boot.
You can turn on the PSU by completely disconnecting the PSU and using a paperclip or jumper wire to short the green wire to one of the neighboring black wires.
http://www.youtube.com/watch?v=5FWXgQSokF4&feature=youtube_gdata
A way that might be easier is to use the main power plug. Working from the back of the plug where the wires come out, use a bare paperclip to short between the green wire and one of the neighboring black wires. That will do the same thing with an installed PSU. It is also an easy way to bypass a questionable case power switch.
This checks the PSU under no load conditions, so it is not completely reliable. But if it can not pass this, it is dead. Then repeat the checks with the PSU plugged into the computer to put a load on the PSU.
If the system beeps:
If it looks like the PSU is good, install a memory stick. Boot. Beep pattern should change to one long and several short beeps indicating a missing graphics card.
Silence, long single beeps, or series of short beeps indicate a problem with the memory. If you get short beeps verify that the memory is in the appropriate motherboard slots.
Insert the video card and connect any necessary PCIe power connectors. Boot. At this point, the system should POST successfully (a single short beep). Notice that you do not need keyboard, mouse, monitor, or drives to successfully POST.
At this point, if the system doesn't work, it's either the video card or an inadequate PSU. Or rarely - the motherboard's PCIe interface.
Here's where you would test the second video card.
Now start connecting the rest of the devices starting with the monitor, then keyboard and mouse, then the rest of the devices, testing after each step. It's possible that you can pass the POST with a defective video card. The POST routines can only check the video interface. It cannot check the internal parts of the video card.
reseat everything (video, ram)
look out for blown caps
make sure no ventilation is blocked
reset cmos
look out for burnt patches
if its a pentium 3, pentium 4, athlon xp etc ITS TOO OLD BUY SOMETHING NEW
if its agp, ddr1, sdr ITS TOO OLD BUY SOMETHING NEW
CPU can't beep
Check your memory
