When does System Restore refuse to put Restore Point down?
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.perform_maintain (More info?)
It's clear that System Restore does not simply put down a given Registry of
a Restore Point instead of one in existence. Before this System Restore
examines for compatibility the coming Registry and established programmes.
Sometimes System Restore adjusts them, makes some corrections and informs
user about this. But in a complicate situation System Restore cannot make
corrections and refuses to put Restore Point down.
Where can I read about:
1) What does System Restore control specifically?
2) In which situation specifically does System Restore refuse to put Restore
Point down?
3) Is it possible to exclude these testings from System Restore?
Thanks in advance
Lev
How to restore the operating system to a previous state in Windows XP
http://support.microsoft.com/default.aspx?scid=kb;EN-US;Q306084
Windows XP System Restore Is Easy to Use
http://www.microsoft.com/windowsxp/using/helpandsupport/getstarted/ballew_03may19.mspx
Frequently Asked Questions Regarding System Restore in Windows XP
http://www.microsoft.com/technet/community/newsgroups/faqsrwxp.mspx
Carey Frisch
Microsoft MVP
Windows XP - Shell/User
Microsoft Newsgroups
Be Smart! Protect Your PC!
http://www.microsoft.com/athome/security/protect/default.mspx
| Point down?
| Thanks in advance
| Lev
Hi Lev,
Microsoft Windows XP System Restore (Windows XP Technical Articles)
http://msdn.microsoft.com/library/en-us/dnwxp/html/windowsxpsystemrestore.asp?frame=true#windowsxpsystemrestore_auto
Troubleshooting System Restore in Windows XP:
http://support.microsoft.com/default.aspx?scid=kb;en-us;Q302796
System Restore "Restore Points" Are Missing or Deleted :
http://support.microsoft.com/support/kb/articles/Q301/2/24.asp
Regards,
Bert Kinney [MS-MVP DTS]
http://dts-l.org/
> given Registry of a Restore Point instead of one in
> existence. Before this System Restore examines for
> programmes. Sometimes System Restore adjusts them, makes
> some corrections and informs user about this. But in a
> Restore?
> Thanks in advance
> Lev
"Carey Frisch [MVP]" <cnfrisch@nospamgmail.com> wrote in message
news:uNwfP$7FFHA.3732@TK2MSFTNGP14.phx.gbl...
> Carey Frisch
> Microsoft MVP
> of
> programmes.
> informs
> make
> Restore
> | Point down?
> | Thanks in advance
> | Lev
System Restore does not automatically create Restore Points for me as the
vent Log 'claims' I have insufficient space. All partitions and drives have
10GB plus free space. Have tried reloading SR but have not yet been able to
solve the problem. Any suggestions? I can create Restore Points manually,
any number on any day, but all but one are deleted after 24 hours
presumeably by FIFO.
Hi Edward,
I would suggest you start by disabling SR on all drives and
partitions.
Do a virus scan with up to date virus software, and a scan for any
installed spyware.
Turn SR back on on the partition where Windows is installed and any
other partition where applications are installed. SR will be of little
use on partitions used for data storage.
Follow the link below and download "XPSystemRestorePointFrequency.vbs"
utility. Click on the script and it will show the frequency on which
Restore Points are created. It should be set to no more than 24 hours.
http://www.billsway.com/notes%5Fpublic/WinXP%5FTweaks/
If you are in need of virus software, here are a couple to choose
from, for free.
Download the software, and in Update Manager run Update
then do a complete virus scan.
Free Offer: eTrust EZ Armor Security Suite from Computer Associates
http://www.my-etrust.com/microsoft/index.cfm
Here is a combination of utilities that works very well in the removal
of Spyware, Parasites and the like:
Ad-aware Personal Edition from Lavasoft http://www.lavasoftusa.com/ is
a free multi spyware removal utility that scans your memory, registry
and hard drives for known spyware components and lets you remove them
safely. Ad-aware PE is does not prevent spyware from being installed.
After installing Ad-Aware and before each scan make sure to run the
update feature before scanning. For large amounts of installed
spyware and such, it may be necessary to run Ad-Aware several times to
clear them all.
Ad-aware Personal Edition finds and removes spyware and the like, it
does not prevent it.
There is no one tool that I know of that removes all known spyware.
Here is a combination that works very well. There is an update feature
in each of these utilities and it *should* be used before they are run
to keep up to date. After these utility are run, re-run them in a week
and see what they pick up.
Here are a couple more removal tools that should also be run.
CWShredder -
http://www.intermute.com/spysubtract/cwshredder_download.html
Spybot: http://www.safer-networking.org/
Spybot Search and Destroy is more powerful and there is a slight
chance of problems. Using WinXP create a restore point first and see
the Parasite Fight link below.
SpywareBlaster:
http://www.wilderssecurity.net/spywareblaster.html
SpywareBlaster is a preventative non-memory resident program.
Spywareblaster does not scan and clean. Instead, it sets flags (or
kill bits) in the registry to prevent the running of a specific list
of bad spyware related ActiveX controls. This includes general spyware
and malicious dialers. It also blocks a list of known spyware related
cookies in IE6.
Regards,
http://dts-l.org/
> Points for me as the vent Log 'claims' I have
> insufficient space. All partitions and drives have 10GB
> yet been able to solve the problem. Any suggestions? I
> can create Restore Points manually, any number on any
Edward
System Restore will create Restore Points for each and every drive /
partition unless told otherwise. As Restore Points essentially only
contain information relating to the windows system there is little point
creating Restore Points for drives / partitions only containing
programme files and or data files.
The way you have phrased your message infers that your 10 gb plus free
space is spread across all drives / partitions. However, only the free
space on the partition containing your Windows operating system will be
taken into account in determining whether it is possible to create
restore points. How large is the partition containing the windows
operating system and how large is the free space on that partition.
If I have deduced the cause of your problem properly it may be possible
to resolve your problem by moving folders / files to another partition.
Where are your temporary internet files and your My Documents located?
Also where is your Outlook Express store folder?
How much drive space is allocated to System Restore for your windows
partition -System Restore -Settings.
Hope this helps.
Gerry
FCA
Using invalid email address
Stourport, Worcs, England
Enquire, plan and execute.
Please tell the newsgroup how any
suggested solution worked for you.
http://dts-l.org/goodpost.htm
"Edward W. Thompson" <thomeduk1@btopenworld.com> wrote in message
news:uUoJ2H%23FFHA.3664@TK2MSFTNGP15.phx.gbl...
> the vent Log 'claims' I have insufficient space. All partitions and
> drives have 10GB plus free space. Have tried reloading SR but have
> not yet been able to solve the problem. Any suggestions? I can
> create Restore Points manually, any number on any day, but all but
> one are deleted after 24 hours presumeably by FIFO.
My thanks to you and Bert for your replies. Unfortunately I have tried all
the methods suggested without result. I run KAV and NOD32 as AVPs and
CWShredder, Spybot S&D, Ad Aware and SpyBlaster so I think I have as much
protection as is available against 'nasties, as there is. I have also run
on line scanners on the machine and as far as I can determine the the
machine is 'clean'. As far as actual free space is concerned the 10GB plus
free is the space free on partition. I take your point re the need to
create restore points for partitions containing data and program files.
I haven't have yet tried XPSystem RestorePointFrequency.vbs but will do so.
This problem, while it seems rare is not unique. I have seen two other
references to the same problem but no solution so far. As I create daily
copies of the Registry using ERUNT the problem for me is an annoyance rather
than 'critical'.
Once more thanks to you and Bert for your kind advice.
"Gerry Cornell" <gcjc@tenretnitb.com> wrote in message
news:%23THUtkDGFHA.3664@TK2MSFTNGP15.phx.gbl...
> Edward
> creating Restore Points for drives / partitions only containing programme
> taken into account in determining whether it is possible to create restore
> points. How large is the partition containing the windows operating system
> If I have deduced the cause of your problem properly it may be possible to
> resolve your problem by moving folders / files to another partition. Where
> are your temporary internet files and your My Documents located? Also
> Hope this helps.
> Gerry
> FCA
>> have 10GB plus free space. Have tried reloading SR but have not yet been
>> able to solve the problem. Any suggestions? I can create Restore Points
>> manually, any number on any day, but all but one are deleted after 24
Hi Edward,
Yes run the RestorePointFrequency.vbs script. Make sure the frequency
is set to no more than 24 hours.
If the Disk Cleanup utility is being used, make sure clean up under
System Restore is unchecked on the More Options tab. Having this
checked will remove all restore points except the most recent one.
Perform this test:
1. Confirm that Task Scheduler Service is running.
a. Click Start, click Run, and then type CMD then press enter.
b. Type Net Start at the command prompt and press enter to make
sure that the Task Scheduler service is up and running.
2. Disable and re-enable system restore to delete all the restore
points on the system.
3. Turn off SR on all partitions/drives other than the one Windows is
installed on.
4. Reduce the "Disk space usage" to just under 1GB.
5. Open My Computer and right click on the drive where Windows is
installed and SR is monitoring, then click properties. Confirm that
the free disk space is over 10gbs as noted earlier.
In SR reduce the "Disk space usage" to just under 1GB.
6. Turn off the screen saver, and adjust the power management options
so the system will not go into standby or hibernate.
7. Use the RestorePointFrequency.vbs script and set the frequency to 1
hour. Leave the system unattended for 1 hour, then check SR for an
automatic RP. Restore points are only created during idle time; for
example, when there is no mouse, keyboard, or disk i/o activity.
8. Check the event viewer to see if there are any events denoting
Restore points being purged.
Regards,
http://dts-l.org/
> tried all the methods suggested
> think I have as much protection as is available against
> 'nasties, as there is. I have also run on line scanners
> concerned the 10GB plus free is the space free on
> partition. I take your point re the need to create
> files.
> seen two other references to the same problem but no
> solution so far. As I create daily copies of the
> rather than 'critical'.
>> every drive / partition unless told otherwise. As
>> Restore Points essentially only contain information
>> containing programme files and or data files. The way you have
>> 10 gb plus free space is spread across all drives /
>> partitions. However, only the free space on the
>> be taken into account in determining whether it is
>> possible to create restore points. How large is the
>> partition containing the windows operating system and
>> how large is the free space on that partition. If I have deduced
>> may be possible to resolve your problem by moving
>> folders / files to another partition. Where are your
>> Also where is your Outlook Express store folder? How much drive
>> your windows partition -System Restore -Settings.
>> Hope this helps.
>> Gerry
>>> suggestions? I can create Restore Points manually, any
Thanks to all, but I have not received an answer to my second question -
Restore Point down?
In other words - very often I can see such message: "restore point failed.
No changes have been made to the system". And I would like to know: why?
I have read many articles, but have not find the answer. In most cases it is
an old Restore Point - 2 - 3 days old. But if it's so, why should I reserve
significant part of my space for System Restore?
Thanks in advance
Lev
"Bert Kinney" <bert@NSmvps.org> wrote in message
news:O47B7LDGFHA.2180@TK2MSFTNGP12.phx.gbl...
> Hi Lev,
> Regards,
> http://dts-l.org/
>> Restore?
>> Thanks in advance
>> Lev
Thanks Gerry. It's a work in progress.
Regards,
http://dts-l.org/
Gerry Cornell wrote:
> Bert
> Your new site looks interesting. Congratulations.
> news:OFip5gaHFHA.3628@TK2MSFTNGP15.phx.gbl...
>> The purpose of the clean boot was to find if something
>> in the boot process is causing SR to fail. You don't
>> mention if anything was found, and if nothing was
>> removed I doubt the problem will be fixed. While
>> troubleshooting you can use the
>> XPSystemRestorePointFrequency.vbs script to speed things
>> up. In the mean time I have created a site for using and
>> troubleshooting System Restore. In this case it may be a
>> good review and make sure we didn't miss anything, so
>> far. http://home.earthlink.net/~mvp_bert/index.html
Edward,
Did you ever get your System Restore problem resolved?
I'd like to know because I have the same, exact problem.
Steve Brigham
stevebrigham@earthlink.net
stevebrigham
"stevebrigham" <stevebrigham.1v5lpv@pcbanter.net> wrote in message
news:stevebrigham.1v5lpv@pcbanter.net...
> Edward,
> Steve Brigham
> stevebrigham
If you are referring to my problem, i.e. SR will not create a Restore Point
due to insufficient space despite there being ample space (10GB) available,
I haven't solved this problem, in fact have given up. I have since
installed Norton GoBack that, with ERUNT, is far superior to SR.
> Restore Point down?
As far as i know, system restore might not be able to put a restore
point when it runs out of disk space. Thanks accepted!!
asim662
