Specs:
Sound Blaster Z
MSI GTX 1080
Vizio E75 x 2 TVs
Vizio SB46514-F6 46" 5.1.4 Home Theater Sound System with Dolby Atmos Soundbar
I've had this PC a long time. Still has a 4770K in it. I've had it connected to a few different monitor/sound setups in the past but I've always had audio out via the sound blaster toslink.
Now that I have an Atoms capable setup, I originally connected it the same way, via the SB toslink but it is a small quality of life issue with the system always switching to ARC from the display after changing the video input from prime or netflix apps or whatever. The soundbar remote is awful and you really need to get up and turn on a light to see what input it's using.
I tested running audio from the GPU HDMI to the TV using the ARC to the soundbar and it seems to work fine so I'd like to use this as default so I can lose the soundbar remote and it will always be on the ARC input. If I have a movie on the main display that the soundbar is connected to via ARC, I can still use the 2nd display for working on the PC with no sound. I do not notice any difference but should I?
If I actually have Atmos content playing on the PC will this be sent to the soundbar via the GPU HDMI through the TV ARC? Would it or would it not work via the SB toslink? Is the SB useless when you have a powered audio system?
PS. sorry for being a dinosaur who still uses a sound card
Sound Blaster Z
MSI GTX 1080
Vizio E75 x 2 TVs
