Whiteboard and application sharing do not work
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.messenger (More info?)
Perhaps you can help
I am using MSN Messenger V6.2
(Windows Messenger is also installed)
Sound, video and file transfer work OK
Looking in Tools/Options/Connection I have the following message:
You are connected to the Internet through a non-UPnP symmetric NAT
(Administrator)
I am connected with a D-Link DSL-504T ADSL router with the following setup
UPnP enabled
Firewall & NAT enabled
DMZ not enabled
Port forwarding
TCP,UDP 1024-1064,1863,6901
TCP 1503,1720,1731,522,389,1503,5190,6891-6900
I am running Windows XP with SP2
Regards
Dave Ogle
Greetings Dave,
The RTC (Real-Time Communications) component which powers the audio conversations of MSN
Messenger can actually establish a connection even without an UPnP (detected anyway) NAT, the
Webcam functionality can do the same (and use a relay server) and file transfer can send
files directly through the server.
However, Whiteboard and Application Sharing do require an UPnP-enabled NAT (even with the
proper port forwarded; 1503) as it needs to send the proper IP information to your contact
(and has nothing to fall back on).
You might try installing the UPnP components in Windows -- click Start, Control Panel, Add or
Remove Programs, Add/Remove Windows Components, and under Networking Services, make sure that
Internet Gateway Device Discovery and Control Client as well as UPnP is installed.
____________________________________________
Jonathan Kay
Microsoft MVP - Windows Messenger/MSN Messenger
Associate Expert
http://www.microsoft.com/windowsxp/expertzone/
Messenger Resources - http://messenger.jonathankay.com
All posts unless otherwise specified are (c) 2004 Jonathan Kay.
You *must* contact me for redistribution rights.
"Dave Ogle" <david.ogle@virgin.net> wrote in message
news:41a7a02e$0$49003$ed2619ec@ptn-nntp-reader03.plus.net...
> You are connected to the Internet through a non-UPnP symmetric NAT (Administrator)
> UPnP enabled
> DMZ not enabled
> Port forwarding
> Regards
> Dave Ogle
Jonathan
Thanks for your quick response to my query
I have done as you suggested, but both UPnP and Internet Gateway Discovery
and Control Client are already installed
It does seem from the message in MSN Messsenger tools/options/connection
that Windows is not recognising my router as UPnP enabled.
Dou you have any other suggestions?
Regards
Dave
"Jonathan Kay [MVP]" <msnewsreplies@jonathankay.com> wrote in message
news:O0ZAlbD1EHA.3452@TK2MSFTNGP14.phx.gbl...
> Greetings Dave,
> conversations of MSN Messenger can actually establish a connection even
> without an UPnP (detected anyway) NAT, the Webcam functionality can do the
> same (and use a relay server) and file transfer can send files directly
> through the server.
> (even with the proper port forwarded; 1503) as it needs to send the proper
> IP information to your contact (and has nothing to fall back on).
> Control Panel, Add or Remove Programs, Add/Remove Windows Components, and
> under Networking Services, make sure that Internet Gateway Device
> Jonathan Kay
> Associate Expert
>> (Administrator)
>> setup
>> UPnP enabled
>> DMZ not enabled
>> Port forwarding
>> Regards
>> Dave Ogle
