RobCherry :
so my ram is 1600mhz, its patriot black viper ram, i have 4x4gb sticks. but when i check programmes like cpu-z or speccy they show it running at around 803mhz?? but in my bios the ram is set to 1600mhz?
why is this?
It is actually 800Mhz. DDR memory transfers data on both the rising edge and the falling edge of the bus clock. There are three equally correct ways to market memory:
The bus clock frequency which in your case is 800Mhz
The module standard which in your case is DDR3-1600, or 1600 megabits per second per IO pin. This can also be expressed as 1600 megatransfers per second, or MT/s.
The bus bandwidth which in your case is PC3-12800 or 12,800 megabytes per second per DRAM bus (channel).
Many marketing departments...
