I just got a new set of fans from Amazon, brand new, and installed them in my case. It's a 3-pack - Cooler Master Masterfan 120mm https://www.amazon.com/Cooler-Maste...n+Pro+120&qid=1617330000&s=electronics&sr=1-1
I plugged 2 of them into the controller, and connected my two 200m front intakes into the controller to take up the last slot, so i just plugged the last one into my motherboard. Nothing should be wrong, but this happens:
I have everything set to a RED color, but this thing is green. When i remove the saturation, it just becomes a Pale Yellow. When i select a GREENish color it shows up RED or PURPLE-ish instead. I had another Fan installed in this that was off-color from what it's supposed to be, as well that was plugged in into the same slot, but it was never too far off. It was always very if not exactly close to being the color I wanted. Removing the saturation only made it look purple-ish white, but it still looked mostly white as would be expected.
Im not sure yet if it's the, or the header ow that's causing a problem. The last fan that was connected to it is also the same kind of fan, but i bought it Singular. It was connected to the RGB header with the two 200mm front intake fans via a Cable Splitter that came with my case. I'm only using it to power the one fan's RGB now, so i don't know what the problem is.
I confirmed that it was connected to the Header properly, as well as the cables were linked properly. I'm going to do more checking while I wait, but does anyone have any idea what could be wrong?
