Hello,
My wifi disconnects and I need to relaunch the wifi connection to make it work again it could happen every 5 minutes, every 1hour. I just sometimes lost my connections.
How to improve it?
I am using NetworkManager, maybe you suggest to use some other alternatives, which ones?
Maybe change network driver to another one, or update this one how to achieve this? I have reinstalled using:
My Invalid misc constatly increases.
I am using 5GHz internet.
Is it a interferance problem, how to solve it?
My last topic what I use for my connection:
forums.tomshardware.com
I have read this:
www.tomshardware.com
How to improve it?
Kernel: 6.4.6-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.4-x86_64
root=UUID=758df14c-2163-4fe3-a0db-2a38fe4278d3 rw amd_pstate.enable=1
amd_pstate=guided iommu=pt amd_pstate=active amd_pstate.shared_mem=1 quiet
splash initcall_blacklist=acpi_cpufreq_init amd_pstate.enable=1
amd_pstate=guided iommu=pt amd_pstate.shared_mem=1 apparmor=1
security=apparmor udev.log_priority=3
Desktop: GNOME v: 44.3 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 44.1
Distro: Manjaro Linux base: Arch Linux
Machine:
Type: Laptop System: HP product: HP Pavilion 15 Laptop PC v: N/A
serial: <superuser required> Chassis: type: 10 serial: <superuser required>
Mobo: HP model: 88D0 v: 78.31 serial: <superuser required> UEFI: AMI
v: F.23 date: 10/05/2022
Network:
Device-1: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw89_8852ae v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 02:00.0 chip-ID: 10ec:8852
class-ID: 0280
IF: wlo1 state: up mac: <filter>
2: wlo1 >
Link File: /usr/lib/systemd/network/99-default.link
Network File: n/a
State: routable (unmanaged)
Online state: unknown
Type: wlan
Path: pci-0000:02:00.0
Driver: rtw89_8852ae
Vendor: Realtek Semiconductor Co., Ltd.
Model: RTL8852AE 802.11ax PCIe Wireless Network Adapter
Alternative Names: wlp2s0
sudo /sbin/iwconfig wlo1 127 ✘
wlo1 IEEE 802.11 ESSID:"W-HUAWEI-B535-6518_5G"
Mode:Managed Frequency:5.32 GHz Access Point: A2:08:3A:18:65:80
Bit Rate=400 Mb/s Tx-Power=20 dBm
Retry short limit:7 RTS thr😱ff Fragment thr😱ff
Encryption key😱ff
Power Management😱ff
Link Quality=59/70 Signal level=-51 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:84 Missed beacon:0
Question - How to connect two routers to one internet?
How to connect two routers to one internet? I recently got internet with a primary router already connected and functioning. From the primary router, an RJ45 cable is connected to the LAN1 port of a second router. However, I'm having trouble setting up the second router. I've disabled DHCP, but...
I have read this:
Why Your Wi-Fi Sucks And How It Can Be Helped, Part 1
Our reliance on Wi-Fi networks is exploding. But the more popular 802.11n gets, the more it seems prone to performing poorly. In this first of two parts, we explore exactly how clients and access points communicate and, well, why your Wi-Fi sucks.
