Hey there,
I just wanted to share my experience on the two topics mentioned in the title, because I could find not that much information on these topics (so search engines could easier find it). If you have read my other topic (https://forums.tomshardware.com/threads/photo-apps-do-not-recognize-wifi-any-more.3790438), then you can just ignore this one. I will mostly copy here just my last message from this topic.
So how I solved the two problems:
Also the problem has been resolved by contacting the support - beside that I looked up in the internet, but without any success (see also here for the solution with pictures: https://ccm.net/forum/affich-1165735-photo-apps-do-not-recognize-wifi-any-more). The guy said, that the WiFi being shared is of that new standard, which is not supported by my devices. However... I do not know... One of my laptops (where the BSOD has been displayed) is okay pretty old, maybe 5-7 years, but another one (where the WiFi network just was missing), it is at highest 3 years old... No idea.
I will try to describe here, what the guy did (unfortunately I saw not everything - he was doing pretty fast 😀 ).
Also he opened the settings of my router (192.168.1.1). From there he opened "Network Setting - Wireless". Then he opened one of the tabs there (do not know what one exactly). There he changed the type of WiFi to be shared (if I remember it correctly, it was selected the bottom one, something with "802.11 ... mixed" in name, and he selected the one 1-2 lines above, also with "802.11 ... mixed" in name, but a bit differently).
The guy himself said, he deactivated AC (whatever it is 😀).
Hopefully it will help somebody
- On one of my laptops my WiFi network was just not visible / displayed
- On another laptop the same WiFi network was visible, but when I tried to connect to it, a BSOD page was displayed with the error "DPC Watchdog Violation"
