I got a Q6600 that is oced to 3.0ghz on a Logysis Alpha Cooler. -
http://www.newegg.com/Product/Product.aspx?Item=N82E16835999010
I live in Wisconsin and this time of year it gets pretty cold. Will it be okay to overclock the cpu to almost 4 ghz leaving the windows open?
These are my idle temps from Everest.
--------[ EVEREST Ultimate Edition ]------------------------------------------------------------------------------------
Version EVEREST v5.50.2100
Benchmark Module 2.5.292.0
Homepage http://www.lavalys.com/
Report Type Report Wizard
Computer XCLIO-PC
Generator Xclio
Operating System Microsoft Windows 7 Ultimate 6.1.7601
Date 2012-09-18
Time 00:52
--------[ Overclock ]---------------------------------------------------------------------------------------------------
CPU Properties:
CPU Type QuadCore Intel Core 2 Quad Q6600
CPU Alias Kentsfield
CPU Stepping G0
Engineering Sample No
CPUID CPU Name Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
CPUID Revision 000006FBh
CPU VID 1.1625 V
CPU Speed:
CPU Clock 3006.0 MHz (original: 2400 MHz, overclock: 25%)
CPU Multiplier 9x
CPU FSB 334.0 MHz (original: 266 MHz, overclock: 26%)
Memory Bus 417.5 MHz
DRAM:FSB Ratio 10:8
CPU Cache:
L1 Code Cache 32 KB per core
L1 Data Cache 32 KB per core
L2 Cache 2x 4 MB (On-Die, ECC, ASC, Full-Speed)
Motherboard Properties:
Motherboard ID 64-1005-000001-00101111-071009-Eaglelake$A0985001_BIOS DATE: 07/10/09 14:51:47 VER: 08.00.14
Motherboard Name Asus P5Q SE (3 PCI, 2 PCI-E x1, 1 PCI-E x16, 4 DDR2 DIMM, Audio, Gigabit LAN)
Chipset Properties:
Motherboard Chipset Intel Eaglelake P45
Memory Timings 5-5-5-15 (CL-RCD-RP-RAS)
Command Rate (CR) 2T
DIMM1: G Skill F2-6400CL5-2GBPQ 2 GB DDR2-800 DDR2 SDRAM (5-5-5-15 @ 400 MHz) (4-4-4-10 @ 266 MHz)
DIMM3: G Skill F2-6400CL5-2GBPQ 2 GB DDR2-800 DDR2 SDRAM (5-5-5-15 @ 400 MHz) (4-4-4-10 @ 266 MHz)
DIMM4: Kingston KCM633-ELC 1 GB DDR2-800 DDR2 SDRAM (6-6-6-18 @ 400 MHz) (5-5-5-15 @ 333 MHz) (4-4-4-12 @ 266 MHz)
BIOS Properties:
System BIOS Date 07/10/09
Video BIOS Date 10/21/11
DMI BIOS Version 1005
--------[ Sensor ]------------------------------------------------------------------------------------------------------
Sensor Properties:
Sensor Type Winbond W83667HG (ISA 290h)
GPU Sensor Type Driver (NV-DRV)
Motherboard Name Asus P5Q / P5Q3 / P5QL Series
Chassis Intrusion Detected No
Temperatures:
Motherboard 27 °C (81 °F)
CPU 33 °C (91 °F)
CPU #1 / Core #1 40 °C (104 °F)
CPU #1 / Core #2 36 °C (97 °F)
CPU #1 / Core #3 27 °C (81 °F)
CPU #1 / Core #4 23 °C (73 °F)
GPU 33 °C (91 °F)
Seagate ST31500341AS 28 °C (82 °F)
WDC WD1500AHFD-00RAR5 31 °C (88 °F)
WDC WD5000AAVS-22G9B1 29 °C (84 °F)
Cooling Fans:
Power Supply 2280 RPM
Voltage Values:
CPU Core 1.17 V
+3.3 V 3.39 V
+5 V 5.16 V
+12 V 12.04 V
+5 V Standby 5.16 V
Current Values:
CPU 27.47 A
Computer XCLIO-PC
Generator Xclio
Date 2012-09-18
Time 00:52
CPU Properties:
CPU Stepping G0
CPU VID 1.1625 V
CPU Speed:
CPU Multiplier 9x
DRAM:FSB Ratio 10:8
CPU Cache:
Chipset Properties:
BIOS Properties:
Sensor Properties:
Temperatures:
CPU 33 °C (91 °F)
GPU 33 °C (91 °F)
Cooling Fans:
Voltage Values:
CPU Core 1.17 V
+3.3 V 3.39 V
+5 V 5.16 V
+12 V 12.04 V
+5 V Standby 5.16 V
Current Values:
CPU 27.47 A
