[SOLVED] Will my HDD password work on the same hardware after motherboard replacement?
Zoltan_7
Hi All,
I have a HDD on which I set the HDD password. I have this password, did not forget it. But in the meantime my laptop had a motherboard failure, so I have to order a new one. My question is, that will my old HDD with y known HDD password boot on the same hardware, but with a new motherboard in place?
I assume it should, right?
What can I do if it doesn't?
Thanks!
"will it work?"
Completely unknown. AS above, different manufacturers do things differently.
Do you have a known good backup of all this data?
Being the OS drive, a full drive backup?
Moving forward, all you can do it try it.
See what happens.
