[SOLVED] Will the NZXT Kraken X52 fit in NZXT H700i ?
SolidFib3r
Commendable
May 8, 2017
11
Hi, I'm new to water cooling but I read the Kraken X CPU Coolers installation guide, and the process seems easy enough for me.
So I have NZXT H700i, and I really like the Kraken X CPU Coolers design, So will the X52 fit the top fan part of my case ? because I saw that the X52 has 240mm fans but its dual, not sure 240mm per fan or both together are 240mm, and if either way will it fit ?
And what's the difference between the Kraken X42 with single fan ? does having Dual fans has a noticeable thermal change ?
Thanks in advance.
The H700i supports up to 360mm rads, so X52 definitely fits.
Also, the larger the rad, the better the cooling performance.
Size difference becomes more significant if u start to do some overclocking, or you are using hot chips like the 9900K :)
Thanks, for confirming, I saw this NZXT page https://blog.nzxt.com/which-kraken-series-liquid-cooler-should-you-use/
And it shows that the Difference isn't significant between the X42, X52, X62 So I'll stick with X52. Seems good enough for me.
