I am looking to upgrade my fan,ram and ssd, will these parts work together? and is the fan ok or is there another one that will work? https://ie.pcpartpicker.com/list/cfpCZZ
I wanted a 240mm one, but I wasn't sure if it would fit the case, like Im very new to PC building and parts, do you think a 240mm one would fit, with the ram and the ssd?why a 120mm radiator?
I mean if u have a small case,ok then,but if you have room for a 240mm one (or a bigger one),always buy the 240mm (or the bigger one ) since it will be much better for cooling your procesor.
120mm radiator ussually isnt enough,especially if you will be overclocking.
240mm radiator is kinda like a sweet spot,for most budget options.
The ram is good,if you dont want rgb,i understand that.
The SSD is top notch.
The only problem i see here is the radiator.
This is the exact name of the case AEROCOOL Cylon RGB Tempered Glass Mid Tower Case.When you are looking to buy a new cpu cooler,always look at the case first.Check the dimensions of the case (not by hand,the dimensions will be on the case manufacturers site),and of the cooler you want to put in it.For Air coolers you look at the case max supported cpu cooler height and width,lenght isnt ussually a problem.Most standard ATX cases support air coolers up to like 170-165mm height.For liquid coolers (AIO's) you look at the fan slots.Ussually if the case support lets say 2x120mm fans at the front,that means it support 240mm radiators (2x120=240).Infact,ill make it easy for u,what is the exact make/model of your case,ill go check it out and tell you the exact cooling posibilities of it.
Thank you for the help! But overall would you say it would be better to possibly even get a better case, for the 240mm or are some of the 120mm coolers good enough to do the job?You case supports air coolers to max 155mm height.
Your case only supports 120mm liquid coolers at the front.
I suggest you go with a good quality air cooler instead of a 120mm aio.
Something like this: https://www.amazon.com/Mugen-Rev-CPU-Cooler-Support/dp/B06ZYB8K77
It has a height of 154,5mm which fits perfectly in your case.
A case upgrade would be nice,i would upgrade to something like Phanteks P300A mesh http://www.phanteks.com/Eclipse-P300A.htmlThank you for the help! But overall would you say it would be better to possibly even get a better case, for the 240mm or are some of the 120mm coolers good enough to do the job?
Will do, I think Ill just go with a case upgrade to be on the safer side, I thought this case was big enough but just shows how much I know lmao. ThanksAvoid the Kraken M22 like the plague: high failure rate.
I guess the pump in radiator design isn't so good on this unit.
I really like the look of that case tbh, I think Im best off upgrading the case and going with a good 240mm cooler tbh. thank you for the help.A case upgrade would be nice,i would upgrade to something like Phanteks P300A mesh http://www.phanteks.com/Eclipse-P300A.html
I found a list of 5 best 120mm aio coolers,take a look here https://techguided.com/best-120mm-aio/
Im unsure whether to overclock, so I think going with the exact specs, but a better more spacious case, might be the better call. someone did tell me before that with the i7 9700k, I should be overclocking it, not 100% sure if he's right but it is an option(with the better aio, of course).1. All of these parts will work fine together but there are a few recommendations. 2 the ram, 3200 is typically the sweet spot for ram and Intel doesn’t benefit as much as ryzen from fast ram so going with 3200 could save you a little bit of money. 3 the aio is smaller but I’m guessing your not over clocking so that will be fine but if you end up overclocking consider getting a bigger aio, for $40 usd you can upgrade to a 240, although I don’t know what it’s like in euros.
Try it,there are tons of guides on how to safelly overclock that cpu,it will only benefit you.Im unsure whether to overclock, so I think going with the exact specs, but a better more spacious case, might be the better call. someone did tell me before that with the i7 9700k, I should be overclocking it, not 100% sure if he's right but it is an option(with the better aio, of course).
You did pay extra for a overclockable cpu so I would research and figure out how to overclock.Im unsure whether to overclock, so I think going with the exact specs, but a better more spacious case, might be the better call. someone did tell me before that with the i7 9700k, I should be overclocking it, not 100% sure if he's right but it is an option(with the better aio, of course).
I was going to overclock today, but I didn't think it would help my current gaming performance because some of my specs arent great atm. my ram speeds are slow and the fan that I have shown in the pc part picker is my current fan. which is the main reason I didn't bother overclocking.Try it,there are tons of guides on how to safelly overclock that cpu,it will only benefit you.
Yeah true, I 100% will overclock eventually, but unfortunately, I don't believe my specs in order to overclock atm. which is why I was thinking new case, new ram, new aoi, then overclock.You did pay extra for a overclockable cpu so I would research and figure out how to overclock.
what is your current specs?I was going to overclock today, but I didn't think it would help my current gaming performance because some of my specs arent great atm. my ram speeds are slow and the fan that I have shown in the pc part picker is my current fan. which is the main reason I didn't bother overclocking.
these are my current specs:what is your current specs?
RTX 2070 8gb
I7 9700K 4.9GHz
16gb RAM 2400 MHz
MOBO: ASUS ROG STRIX Z390-F Gaming
600w PSU
Cooler Master MasterLiquid ML120L
also a 2TB HDD.
[/QUOTE download prime 95 or some kind of cpu stress test and see what temps you hit under full load that should give you some kind of idea if you could overclock
I see, how can I check the temp while the test is going? have no idea about this type of thing“Zhnarkov” (Reddit)
"Pinhedd: "Both IBT and Prime95 are similar in that they stress floating point arithmetic and memory subsystems. They are different in that IBT uses Linpack (solving linear equations) while Prime95 calculates Mersene Primes.
IBT is generally regarded as being far more aggressive in the short term, which makes it great for testing ultimate stability. IBT will easily drive load temps up to 20 degrees higher than Prime95, this is well known and is a defining feature of the program.
Unfortunately, the Linpack benchmark was designed for supercomputers (hence the floating point part, for modeling continuous phenomenon) so it really pushes desktops to the limit, far beyond what any application will do. This means that IBT may fail on commercial CPUs that are running at stock settings simply because Intel doesn't test them to that extent.
NZXT cam software or if your on the latest version of windows there is the temps in task manager there is a couple other softwares but that’s what I use.I see, how can I check the temp while the test is going? have no idea about this type of thing
cpu running at 67-70 during the test and gpu at a steady 56.NZXT cam software or if your on the latest version of windows there is the temps in task manager there is a couple other softwares but that’s what I use.
