Will this power supply work?
For a system using a single Radeon HD 6770 graphics card AMD specifies a minimum of a 450 Watt or greater power supply. The power supply should also have a combined +12 Volt continuous current rating of 24 Amps or greater and have at least one 6-pin PCI Express supplementary power connector.
The Corsair Builder Series CX600 V2 (CMPSU-600CXV2), with its +12 Volt continuous current rating of 40 Amps and with two (6+2)-pin PCI Express supplementary power connectors, is more than sufficient for your build.
Total Power Supply Wattage is NOT a crucial factor in power supply selection!!! Total Continuous Amperage Available on the +12V Rail(s) is the most important.
mainly i meant run good not ood but ok that is ok someone i know needs a computer and he is having trouble so this is what he is getting hopefully this will run good on 1080p
Hi!
I still want to know how good you want it to run?
Do you mean its not smooth?
im just wondering about the power supply beacause he really wants his computer and i want to make sure this will work good
ok well he really wants to play ay 1080p so im trying to get him the best computer for what he has
