So, long story short,wanted to upgrade to Ryzen from my basic Intel build. Got the PSU first as it was being given under some discount. My old one was 450W, and the new one is 650W. I'm posting the link of the PSU here, hope you guys can access it:-
Antec VP650 P Plus 650 Watt 80 Plus Power Supply with 85% Efficiency https://www.amazon.in/dp/B07WSHNG28/ref=cm_sw_r_cp_apa_i_zMj4Db02WBPNF
I am willing to go with Ryzen 2600x , and an MSI X470/X 570Motherboard. Hence I went to pcpartpicker.com and tested my intended combination: MSI x470 Gaming Pro motherboard ( https://www.amazon.in/MSI-X470-PRO-...r_1_1?keywords=MSI+x470&qid=1575005867&sr=8-1 )/ MSI X570 A- Pro Gaming Motherboard ( https://www.amazon.in/MSI-Component...r_1_5?keywords=MSI+x570&qid=1575006002&sr=8-5 ) along with Ryzen 5 2600X and GTX 1660Ti along with the PSU I already have (Antec CP650P Plus). In case of both of the Motherboards, it showed me as a Note the following : - "The MSI X470 GAMING PRO ATX AM4 Motherboard has an additional 4-pin ATX power connector but the Antec VP PLUS 650 W 80+ Certified ATX Power Supply does not. This connector is used to supply additional 12V current to the motherboard. While the system will likely still run without it, higher current demands such as extreme overclocking or large video card current draws may require it."
Hence, my question is does it mean that the PSU I already have, won't go hand in hand with the Mobo I intend to build on? I have checked combinations with B450 Motherboards also, and in that case there was no such Note/Warning like this one. I cannot return back the PSU at this point and on the other hand, I would very much like to go ahead with at least a X470 build. Please, advise me on what should I do- should I go ahead with the X470/X570 plan or stick with the B450 Platform?
Also, i would like to thank in advance for all the kind souls who has read so far
This is my first post here and I do not post so much on the Internet Forums so please excuse me for any kind of wrong formatting/mistakes !
