• Our team is working to address issues posting quotes or media to the forums. Please bear with us as we get this sorted out.
Question Will USB 3.2 with a PCIe 3.0 x2 be compatible with a 2.0 header?
Jul 11, 2021
Basically, I have the MSI b450 gaming carbon max wi-fi and my PC case has a USB C connector (MSI Gungnir 110R) and the motherboard doesn't have the matching header. I want to buy an adapter (https://www.overclockers.co.uk/silverstone-sst-ecu02-e-1x-usb-3.2-internal-pcie-3.0-x2-low-profile-cc-01d-sv.html) but I'm not sure if it's compatible with the motherboard with the different 3.0 and 2.0. will I lose any speeds for transferring or anything like that? And if it's compatible where would I plug in the adapter? Any information is appreciated as I have no idea about this stuff. If you have any better solutions to be able to use the USB C port for charging and data transfer it would also be very appreciated.
lvt
Commendable
Apr 19, 2021
1,724
276
1,640
39
You should pick another card with solid capacitor (may cost a couple of dollars more).
Basically if all you need is an USB-C connector, this card will do the job.
mikewinddale
274
29
4,840
24
The card you linked should do just fine.
But since you mentioned charging, I want to point out that a regular USB-C port does not support USB-PD (USB Power Delivery) or Qualcomm Quick Charge. So don't expect fast charging.
To get fast charging out of a PC's USB-C port, you need Thunderbolt. Right now, Thunderbolt PCIe cards only work if your motherboard has a Thunderbolt header, so that's basically out of the question. So I just want to make sure you realize that your charging won't be fast.
