Hello,
I want to know if 939 X2 3800+ be faster than CONROE 1.86 GHz.
I am considering it after the price drop.
Rgds,
Rgds,
No.Hello,
Rgds,
Fortunately, does not make any diference for the non-fanboys. And fortunately it makes PAIN IN THE A$$ for the AMD fanboys like you.Fortunately for the Intel fanboys No.
and more expencive than.But don't let that stop you because there are plenty of Intel chips that it is faster than.
Gee, i missed were he said it was for games. :roll:He should still go for a 3800+ or a 4200+. It will be enough for games though not for bragging rights.
Then factor in that AM2 requires the best DDR2 money can buy, to perform decently(more money), whereas Conroe doesn't.That's true, but consider the price of a Conroe motherboard vs. a 939 or AM2 board. Sure the CPU itself is priced the same or better, but when your motherboard is $200+ the small savings on the CPU is no longer relevant.
http://www.newegg.com/Product/Product.asp?Item=N82E16813121016
http://www.newegg.com/Product/Product.asp?Item=N82E16813131025
Again you failed to impress me. If you googled around to find any info (city from my country) that does not make you a geography Ph. D. But I am sure you'll claim that you are, just like the 50 jobs you are doing in parallel.Just because you live in a cave outside Bitola, I'll forgive your misspelling of EXPENSIVE.
Not every Conroe-compatable mobo is going to be $250+ either. Just realize that it isn't just black or white here, and if price were his only criteria, he wouldn't have only asked if the 3800+ is faster. He would have asked which is cheaper.Nothing is required; you act as if he expects the best performance possible on a budget, well that is not going to happen no matter what memory he buys. Even with the more expensive memory, the $250 price on the Conroe motherboard vs. $100 on an AM2 board still doesn’t make up the difference. I’m not saying that the Conroe isn’t a good chip, because that’s far from the truth, it’s just the savings are not as great when you are actually buying a complete system.
http://www.newegg.com/Product/Product.asp?Item=N82E16820145526
http://www.newegg.com/Product/Product.asp?Item=N82E16820145566
I believe Yes. 3800 can overclock to 3ghz stock HSF and prime stable, plus. AMD’s are SLI ready. The E6300 is 2mb cache and will be slow in games. check the link below. I am seeing a lot of privileged Intel's front runner fanboys who advertised for conroe w/ their cherry picked ES, beginning to show their dissatisfactions and complaining about "conroe being hot", "motherboards frying", "no good bios available", "Can not overclock and be stable",
"Motherboards and chipset FSB overclocking limitations" and plenty other complaints.
These are the same "privileged" fanboys who where cheerleading conroe for the past 2.5 months.
Best to wait for retail version and non "super cooked" ES’s hit the market and average un-bias users report their findings here and in the other forums.
http://www.ocforums.com/showthread.php?t=465961
That is true, but seeing as he's choosing between a budget Conroe and an X2 3800+, I'd say price is a factor. If price had no bearing, I'd say get the E6700.Not every Conroe-compatable mobo is going to be $250+ either. Just realize that it isn't just black or white here, and if price were his only criteria, he wouldn't have only asked if the 3800+ is faster. He would have asked which is cheaper.
You fail to be objective and loose your sense/head when someone doubts your master. a sign of weakness and clear pattern from Intel's side of things.mjp1618
Well, I guess the best way to get attention in a room full of intelligent people is to act like an idiot.
Hello,
Rgds,
