WINTV-GO AND CABLE MODEMS
James
1,388
Archived from groups: rec.video.desktop (More info?)
I need to run a splitter from the cable modem to the WINTV card but
does not seem to work. Also have a splitter from VCR to modem. Any
ideas or suggestions?
Thanks in Advance
JV in Florida
In article <5f754003.0404260717.3ed21316@posting.google.com>,
Two two-way splitters will each divide the amplitude of the incoming signal
by two, subtracting about 3 dB, so you would have
0 dB +--------> -3 dB
------| +----> -6 dB
+----> -6 dB
One three-way splitter will divide the amplitude of your incoming signal by
3, subtracting about 4.8 dB from each output, making
0 dB +--------> -4.8 dB
------|--------> -4.8 dB
+--------> -4.8 dB
So which to use depends on whether you have a device that's particularly
sensitive, and whether you already have one of the above. If you change the
level to your cable modem, they may have to adjust it, but in my case
there's a frequency filter before the cable modem, to filter out the TV
data. Make sure you do any changes _after_ the computer splitter (NOT the
filter).
-eben ebQenW1@EtaRmpTabYayU.rIr.OcoPm home.tampabay.rr.com/hactar
A: Because it looks dumb and is hard to read.
Q: Why is top-posting wrong? -- from lots42@xxx.com
