[SOLVED] Wired controller flashing when using USB hub.
walshi
Hi all,
When I connect my wired game controller (Xbox type) via a USB hub, the green ring light on controller continually flashes a solid green ring.
However, if I plug it directly into a USB socket it stops flashing with just the top right segment lit as normal.
When the light is flashing it still appears to work as normal but it's disctracting and annoying!
I've tried different controllers with same result. I've also tried the hub and controller on a different PC and it's fine. Therefore it seems to be an issue with my PC?
Any ideas ??
