So I contacted CDprojekred about this issue and they said that is was because of my dual core Pentium G3258. The Witcher 3 needs a more powerful CPU, but before update 1.08, users have been able to run The Witcher 3 just fine on dual core CPU's. Now. it just randomly freezes for 5 seconds (more persistent in city areas). It'll be a while until I can upgrade my entire system to an AMD Ryzen CPU, so what can I do to make the Witcher 3 run better? Does anyone else have this issue on dual core CPU's? My CPU is OCed to 4GHz.
These are the things I did to try and solve the issue, but did not work:
Update GPU drivers.
Increase GPU power. (Not overclocking, just power input)
Lower game settings. (Mixture of low and mid)
Use BES battle encoder. (Made the game run even worse)
Increase CPU ring ratio to match the CPU frequency.
None of these worked. What can I do to make the game run without randomly freezing for 5 seconds. If there is no solution, I'll just wait until I get an AMD Ryzen CPU.
Update GPU drivers.
