XP system start up
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.perform_maintain (More info?)
I have recently ran Spybot to remove spyware. Now when I reboot, it's trying
to start some of those or reference programs or dll's. How do I search my
start up info to remove this program from the startup info. Note: I have
already ran MSConfig and didn't see any reference to the programs that are
reporting that they can't start.
You probably still have referrence to those items in the registry.
Start | Run | Type: regedit | OK |
Navigate to >>>
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run
And
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run
See if there are any references to those files.
Also look here >>>
C:\Documents and Settings\All Users\Start Menu\Programs\Startup
And
C:\Documents and Settings\Your Name Here\Start Menu\Programs\Startup
Hope this helps. Let us know.
Wes
In news:CBC6FE2F-5690-4EBF-9951-A296C6B32A3E@microsoft.com,
kobe <kobe@discussions.microsoft.com> hunted and pecked:
> it's trying to start some of those or reference programs or dll's.
> How do I search my start up info to remove this program from the
> startup info. Note: I have already ran MSConfig and didn't see any
> reference to the programs that are reporting that they can't start.
Spyware can be notoriously difficult to remove completely. You should have
another spyware remover on hand in case the first program doesn't do the
trick.
If you know exactly what spyware you have/had, you may be able to find
manual removal instructions specific to that spyware on the web sites of the
major anti-spyware organizations. Otherwise, you're going to have to try
another spyware remover, and if that doesn't work your fastest solution is
reinstalling your software.
Ted Zieglar
"kobe" <kobe@discussions.microsoft.com> wrote in message
news:CBC6FE2F-5690-4EBF-9951-A296C6B32A3E@microsoft.com...
trying
kobe,
Pieces of the spyware was left behind. Bazooka Spyware Remover does an
excellent job of finding the left over pieces and tells you how to remove.
the Link to the authors site:
http://www.kephyr.com/spywarescanner/
Redhead
"Ted Zieglar" <teddyz@notmail.com> wrote in message
news:OnYvGe1xEHA.2788@TK2MSFTNGP15.phx.gbl...
> trick.
the
> Ted Zieglar
> trying
my
have
are
