Hello, I just finished building 2 PC's, the first one is working flawlessly, but the second one is not posting at all, and the yellow DRAM led on the motherboard is constantly on.
I have (the 2 computers have the exact same specs)
CPU AMD 7600x
Motherboard: Asus B650-Plus-Wifi
Power supply: 850w ASUS
Ram: G.Skill Trident Z DDR 5 32GB
I've done the test without the GPU as I see no reason for it to be installed during troubleshooting
I feel like I have tried all troubleshooting steps.
Updated Bios to the latest version.
Cleared CMOS multiple times, both removing the battery and shorting the pins.
I've tested with ram sticks that I know are working, 1 at a time in all the ram slots (from the other pc)
I've bought a whole new motherboard, as they refused to give me a new one (lol, probably because they realized nothing was wrong with it)
I've reseated and tried all of the ram slots with 1 stick at a time
I've tried loosening the CPU cooler
I've tried plugging the power supply cables in and out and I've made sure they're all plugged in all the way
And I'm at a loss...
The same thing still keep happening even with the new motherboard.
When I try to start it, it doesn't cycle through the different leds, and it just goes straight to constant DRAM led. Which is what leads me to believe it might be the CPU.
In my opinion this leaves the only reasons to be either the CPU or the Power Supply.
Before I RMA the CPU I'd just like to hear if you have any other ideas that I might've not tried.
I can't be bothered to take the whole other computer apart, since I'd have to take out the motherboard, CPU cooler and CPU and to replace it with my (maybe) defective cpu as I am a bit scared it will mess up the other setup 😅
Looking forward to hearing y'all thoughts.
CPU AMD 7600x
