I bought Z690 DDR5 and while installing cables from PSU I found that 8pin cable connectors aren't the same that motherboard 8pin connectors are like.
ALTHOUGH, the cable can plug without any problem but the shape of every single one isn't the same that looks on motherboard.
Motherboard 8pin connectors are like:
Square, D, D, Square
D, Square, Square, D
But the one that goes from PSU is like this
D, Square, D, D
Square, D, D, D
It can be plugged but I'm scared of the differences.. Should I install it and go on or the cable connectors should be exactly the same as the motherboard ones?
Thanks.
D, Square, D, D
Square, D, D, D
Thanks.
