• Find an incredible deal for Black Friday or Cyber Monday? Share those epic bargains with the community by posting them in this forum thread!
Question Zotac GTX 1050 Ti Probably Dead. Need Help.
Scorpionk
Commendable
Jun 25, 2017
Hi All,
I need some help regarding my graphic card. So it all started few months ago, every time I turn on my PC, it boot loops (Monitor shows windows loading and again restarts) for several times before it actually boots up. I thought it was due to windows 10 update. But Even after few updates, It didn't stopped.
Few days ago, after turning on PC, my monitor didn't get input signal. No display. PC went into endless boot loop. GPU fan spinning but no display.
listing out few things that I tried out.
  • I tried changing RAM into different slot.
  • I tried changing Hard disk SATA port
  • Switched to Integrated GPU and PC is alive again. No boot loop. Everything is working fine.
  • Tried Graphic card into friend's computer. with exact same config as mine. and he's PC also went into boot loop with no display.
My graphic card is 2 years old
PC Config:
CPU: i5 6500
RAM: 8GB DDR4 2300 mHz
GPU: Zotac GTX 1050 Ti OC edition (but never Overclocked)
PSU: Corsair VS450
MotherBoard: GigaByte H110M S2
I'm 99% sure that my graphic card is dead. Also it is already crossed warranty. (2 years) Should I repair from Zotac authorized service center (I live in India.)? Or should I buy new one? If yes please suggest good card which will fit good for my current PC config.
Fix_that_Glitch
Commendable
Mar 31, 2019
2,139
170
1,690
97
First try to reflash the bios on the card. It may bring it back to life, can't hurt anyways. If it stays dead then you could go with an AMD RX 590. You can get the Red Dragon version for $190 u.s. on Amazon.
