SOLUTION : The GPU seemed firmly seated, but apparently it wasn't. Simply had to reseat it and it fixed it, for now
Hey !
I've been using my new RTX3080 (This one) since november 2020 and it worked perfectly until very recently.
I've got 3 monitors plugged into this gpu :
I've been assuming that it might have to do with the higher temps that have come with the summer, increasing my pc heat a bit, but nothing never goes above the expected temps.
The audio usually keeps running while the signal is lost, so I guess that the system isn't freezing. The only way I've found to resolve this is to power shutdown the computer, holding down the power button.
It happenend a few times now, 3 or 4 times across a period of ~50 days I'd say.
Here are my specs :
Edit : I previously owned a 2080ti which I got refunded because it ran at abnormaly high temperatures, with fans spinning fast all the time. That makes me wonder if the issue might be coming from my motherboard... Don't know.
Thanks !
Hey !
- 1920x1080 60hz
- 2560x1440 144hz
- 2560x1440 60hz
Here are my specs :
- Motherboard : Aorus z390 Ultra-CF
- Intel i9 9900K (stock clock)
- AORUS GeForce RTX™ 3080 MASTER 10G (stock clock)
- 32Gb RAM 2x Corsair Vengeance 16Gb DDR4 3200Mhz
- CPU Cooler : NZXT Kraken X72
- PSU Corsair RM750x 80PLUS Gold
Thanks !
