Question 4090 and power cables
Apr 14, 2024
I recently built a new pc with tuf gaming 4090 oc edition and I cant close the case with that 1 to 4 pin psu connector. I'm looking to buy Corsair Premium 600W PCIe 5.0 / Gen 5 12VHPWR PSU Cable - Fits Type-4 PSUs via Dual 8-pin PCIe - 12+4pin to go into a evga supernova 1000w g+ psu. With only two connectors to the psu will this be fine?
Psu- EVGA SuperNOVA 1000 G+, 80 Plus Gold 1000W, Fully Modular, FDB Fan, 10 Year Warranty, Includes Power ON Self Tester, Power Supply 120-GP-1000-X1,Black https://a.co/d/7oed0TS
Cable- Corsair Premium 600W PCIe 5.0 /... https://www.amazon.com/dp/B0BLXWHW2N?ref=ppx_pop_mob_ap_share
Gpu- ASUS TUF Gaming GeForce RTX 4090 OC Edition Gaming Graphics Card (PCIe 4.0, 24GB GDDR6X, HDMI 2.1a, DisplayPort 1.4a) TUF-RTX4090-O24G-GAMING https://www.newegg.com/asus-geforce...m_mmc=snc-social-_-sr-_-14-126-594-_-04142024
Although cablemod has had major issues with the right angle adapters there simple cables seem to have no issue.
They make cable that will fit your evga power supply.
In many cases a cable from a corsair power supply will not plug into another brand of power supply. It is actually a good thing you hear people all the time using cable that fit but are wired different and it can destroy the power supply and equipment.
I would not even think to try the corsair cable you list unless you have found something that says it is 100% the same cable as your evga power supply.
Reactions: buffetbuster
Apr 14, 2024
Thank you.
