AMD 6670 overclocking problem BSOD!
peiri
15
i have recently purchased AMD radeon 6670. i can overclock it slightly ex:GPU clock 850mhz memory 885mhz
but when ever i try to over clock it to GPU clock 900mhz(max) and memory 1000mhz and start a game i get BSOD
need some help/advice
Thanks
i have the MSI after burner but i cannot increase the core voltage it's locked
You have to go into the settings within MSI Afterburner to unlock the voltage control.
Also I should let you know that you should be careful while messing around with these settings.If you don't know what your doing you can cause damage to the card.Always watch your temps and don't exceed 80c.And don't increase the voltage a whole lot.Just a very small amount at a time.You should download a stress testing program as well to test if what speed you have it at is stable.
Actually I just found something that might help you.I totally forgot you have to edit some settings in the MSI Afterburner file.
Yea make sure you open up Catalyst Control Center, go to ATI Overdrive, and first unlock the card and second disable (uncheck) the ATI Overdrive box. Secondly, in MSI Afterburner, make sure you change the config file where it says "allow unofficialoverclocking =" from 0 to 1. Then you should be good to go.
Tell me if that works for you
meaning my card doesn't have a 6pin connector
