Hello kind people, i have a problem with my asus laptop n5522vx , so, i noticed that my battery has probably died,i took it off, and now when i plug in my laptop to power it turns on then after a few seconds it turns off then turns on again by itself and works normal, then i tested it again to see if this will happen again, so i shut down my laptop pull out the power supply and when i plug it on again it does the same thing again, but if i shut it down and leave the cable on it works normally, it started doing this while the battery was in the laptop and it is doing it now without the battery, so i am wondering what could it be? thank you
