Question Backlight Bleed or Something Else ? - BenQ SW271 Photoediting monitor Problem.
himanshucbhagat
Hi Guys,
I am facing a major problem with my brand new BenQ Monitor SW271 Photoediting monitor. I am having a greenish light bleed from the corners of the monitor. I have replaced the monitor 2 times from the shop & they replaced it with brand new Boxpack display at my doorstep both the times. After 15-18 days, this light leaks appeared as bright greenish spot on the corners. Initially it is small & it becomes larger over the time.
View: https://imgur.com/a/j37Uzn2
To my surprise I have replaced it 2 times, and Currently I am using the 3rd BenQ SW271 Display which I got after replacement & its is showing the same problem as before. The photos attached are of the last display but I am facing same issue right now. Is this poor manufacturing or faulty piece or there is something wrong at my end. I am using an UPS APC BR1500G battery backup which is kept behind my display.
Please guide me the right way. Hope to get the help here. Thank you.
Latest posts
