Hi, I'm looking for an air cooler for my i5-2500K. At first I was considering the NH-DH14 but I think it would be a bit overkill for my needs. I haven't overclocked before so I'm not going to go over 4.5GHz. I'm looking for a cooler that can keep the CPU under 70 degrees Celcius under load and preferably quietly. It seems the CM 212 Evo is a really good cooler (at least for its price, I could get it for 30€ whereas the NH-D14 costs 80€), would it be a good choice for me? If yes, do I need to buy thermal paste separately or is it included?
If you for some reason need to know my computer specs they are as following:
ASRock Z68 Extreme3 Gen3
Intel Core i5-2500K
MSI N560GTX-Ti Twin Frozr II
Ripjaws-X 8Gb(4x2Gb) 1600MHz
Thanks
Intel Core i5-2500K
Thanks
