Best graphic cards for 300 watt power supply
ebaylover24
47
It glitched out it didnt say it posted how about you find yourself a woman and grow a few inches because I'd be pretty mad and triggered about a PC website too if all I had to do all was be on this website so hop off my post if you dont like it . its quite simple .
If the RX 460 is cheaper than the GTX 1050 then get it, but the GTX 1050 is better than the RX 460. Some RX 460 require a 6-pin PCIe power connector. If you have a 300W PSU that came with a prebuilt it likely does not have a 6-pin PCIe connector.
Similar threads
