Please keep it to 1 thread.
So I just transferred my components to the Sama IMO1 PRO case and the temps for my GPU are 4 degrees hotter than they were, both at idle and max load. I have an Asrock Challenger RX 6650 xt (picture below) and was wondering if I should put the case fan I have under it more to the right side of the GPU or the left ( or wherever). Like is there a hotter spot I should be targeting with airflow?
