PC specs:
Windows 10, 21H2 running on an i5-7500 desktop PC.
Recently added a TPlink UB500 for Bluetooth 5.0 connectivity.
ISSUE: I have already paired my Bluetooth earbuds with my PC, but it does not reconnect automatically after a disconnection in cases such as
-----------1. I go somewhere distant and come back
-----------2. I turn the headphones off and on again
I have to manually open the Bluetooth settings page and make a few clicks: Add a Device-> Allow -> Done.
However, once connected, it reconnects if I Disable/Enable Bluetooth in Windows Settings, but that same trick does not work for events 1 & 2 above.
The issue is repeatable on a few other PCs and other Windows versions, and other Tplink Bluetooth adapters.
In the case of a laptop featuring an Intel Bluetooth 5.1 module, the headphone auto-connects seamlessly with no issues.
TRIED BUT FAILED:
I already tried with no luck:
1. Enabling: 'Allow Bluetooth Devices to find this PC' under Bluetooth settings->Options.
2. Changing the Bluetooth Trigger to Automatic in the 'Services' app of Windows.
EXPECTED SOLUTION:
I believe it could be related to the Windows drivers/settings for Tplink UB500 adapters. It may be power management or something else.
I wish there were a workaround to avoid the additional clicks required every time.
TRIED BUT FAILED:
EXPECTED SOLUTION:
