Hello!
After a failed attempt to get my USB device to work when plugging it into the front panel of the case, I instead tried to plug it directly into the motherboard ports. When doing so, the computer shut down and attempting to boot it up again would result in failure. No sounds and nothing showing up on the screen.
So I tried to find out the cause by removing RAMs, trying out 1 stick at different lanes, tried to unplug/plug the PSU cable etc. This is when I found out that my USB 2.0 header was not properly connected. It was connected too much to the right, meaning that it did not have the 2 pins on the left side connected.
Can this cause my motherboard to short? Is there anything that can be done?
Thank you!
Edit:
MOBO: MSI B85-G43 GAMING
OS: Windows 10
PSU: Corsair 650W
RAM: Corsair Vengeance DDR3
GPU: MSI Geforce GTX 980
CPU: Intel i7 4th gen, do not remember specifically which
Thank you!
Edit:
OS: Windows 10
PSU: Corsair 650W
