Question can i plug a AIO Cooler into a RGB hub
Sep 15, 2019
ok im working on a mATX build and unfortunately my motherboard only has three 4-pin headers so to fix this problem I decided to get a fan hub and a rgb hub which got me wondering can i plug my AIO Cooler (which has RGB) in to that RGB hub.
and just to clarify im not talking about the pump im talking about the one that controls the rgb on the cooler
The RGB headers are rated for 5v or 12v?
The AIO: are the fan and RGB connectors combined into one, or separate? Combined would be 12v, separate would be 5v, but you should check the manufacturer's specs to be sure.
You can't plug a 12v power into a 5v header, or you will burn the header out.
