Hello,
first off, I'm new to this forum and I'm currently working on my first PC. I'm sorry if a answer to this question already exists, but I haven't / couldn't find anything about it.
So here's my question:
I'm planning to buy the Pure Loop 2 from Be Quiet.
I have a Deepcool Matrexx 70 3f case and I want the fans to match (This case is using the Cooler Master CF120 fans [3x120mm] at the front and one at the back). They're all A-RGB while the Pure Loop 2 doesn't uses A-RGB fans. I know that you can swap fans on the most AiOs, but I'm not sure if that'll work If the original fans don't have A-RGB (They're 3x120mm Silent Wings 2).
Specs:
-Cooler Master Matreex 70 3f
-B550-F Gaming Wifi
-Ryzen 7 5800x
-Pure Loop 2 (hopefully with RGB fans)
-2x1tb Samsung 980 pro
-G. Skill Trident Z RGB 64gb (2x32gb) 3200mhz
-RTX 3080 MSI VENTUS x3
-Be Quiet Straight Power 11 750W 80+ Platinum
Thanks for all answer (or questions), I would really appreciate them!
Specs:
-B550-F Gaming Wifi
-Ryzen 7 5800x
