Here is what I mean.
I want to buy Raidmax NV-R120FBR3 kit, which is basically a set of 3x Raidmax NV-R120FB ARGB Aura Sync compatible fans, an ARGB 5V controller/HUB and an RF Remote.
I own an ASRock H270M Fatal1ty Performance motherboard, that is not ARGB compatible, meaning it does not have an ARGB header I can connect the fans to (although it does have an RGB header, but in this case, I have no use of it).
I plan to buy a MOBO with and ARGB header that is also Aura Sync (or maybe Mystic Light Sync compatible, will probably go with Aura) in the future so I could sync them all up and control them through the software. I don't want to be spending money buying RGB fans now and buying ARGB ones later. Not economic.
So, I want to know can I plug the ARGB fans into the ARGB 5V HUB and mess with the speed, modes and colors through the RF remote included? And in the future I will get an ARGB compatible MOBO, as stated above.
From what I know, yes, I should be able to do that. I can connect the fans with the molex to my PSU for power.
Please tell me if I git something wrong and, in case I did, what that something is.
Thanks in advance and cheers.
Edit; So, in reality, the fans would not even be connected to the MOBO, but I am interested for them working with the ARGB HUB.
