Changing control alt delete sequence
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.security_admin (More info?)
Hi,
Can someone please tell me how I can map the Ctl-Alt-Delete sequence to
some other key sequence (say 1-7-9) ?? I want to continue using the
"Press CTL-ALT-DEL to continue.." but want to press 1-7-9 instead of
CAD to the same effect. I am using a custom gina stub also.
Kindly help!
Regards
Kits.
> to some other key sequence (say 1-7-9) ?? I want to continue using the
Interesting question. Initial research points to "no way".. However I will
be watching this thread and hope that if you do find a way - you share.
<- Shenan ->
The information is provided "as is", it is suggested you research for
yourself before you take any advice - you are the one ultimately
responsible for your actions/problems/solutions. Know what you are
getting into before you jump in with both feet.
