Question Chasis fans not responding to bios settings
Celalyvan
45
ok so, my setup is the following:
case: Lian Li Lancool III
Motherboard: Asus ROG Strix B500-a
Since I also have an ROG mouse, I installed armoury crate, mostly for it (yeah i know, it sucks).
So, what's the matter?
Case front fans are frikin loud, and they don't listen to what I set on the bios fan curve they go full power at +70°C (CPU package temps acording to HWMonitor).
What I fear is that the Armoury Crate fan controller is being prioritized over the bios one, is there any way to nullify those AC fan settings /uninstall them?
Or what else can I do? I wouldn't like to uninstall the entire thing becouse I also use it to track my mouse's battery and lights
Thanks!!
Can you check and see how the fans in your case are hooked up in the system? Uninstall Armory Crate using the uninstaller app found on your motherboard's support site and you should be able to manage the fans in BIOS, if the fans are teetered to the motherboard's fan headers.
ok, the 3 fans are connected to a 3:1 wire, wich is connected to the CHA_FAN3 connector in the motherboard
