Coming out of console mode. Vampire bloodlines stops running
Cheshirecat
12
Archived from groups: comp.sys.ibm.pc.games.rpg (More info?)
When I leave the console mode in vampire masquerade bloodlines, I lose
control of the keys and mouse. The game cursor is replaced with regular
windows cursor and I can't move round etc. The only key that works is the ~,
so I can reenter the console, and I can type fine in there. It's as if focus
has been lost from the game window.
Any ideas please?
hermann
42
> bloodlines, I lose control of the keys and mouse. The game
> cursor is replaced with regular windows cursor and I can't
> move round etc. The only key that works is the ~, so I can
> focus has been lost from the game window.
> Any ideas please?
Common "bug" (console modes are typically not supported), IIRC.
A quick and dirty fix which worked for me was to exit the console by
entering the character screen (command "charedit" or "chareditor" - can't
remember which) and then closing the console.
The character screen uses a cursor, and when you exit that screen, the mouse
actions will be captured as normal.
G
Guest
Guest
"CheshireCat" <hah@notonyournelly.coom> wrote in message
news:35nmvbF4mvdnjU1@individual.net...
focus
> Any ideas please?
The Bloodlines console has the typical 'x' box that one normaly uses
to close a window.
If you enter a console command when the console first appears
on start up, you can close it by clicking the x.
If, however, you open the console after you have loaded a game,
you have to enter the tilde symbol (~) to close it, otherwise
it will freeze as you described.
Joe
