Thanks for replying Que.
Actually my problem seems to be more serious than the bad solder of the jack pins. When plugging the ac adpter (without the battery wich is died) the led of the charger keeps blinking dimm and nothig happens when pushing the power switch.
So, I'm pretty sure that i have a short circuit on the board since the voltage between the positive and the negative pins of the jack is 0ohm.
I took apart the laptop and desoldered the jack connector from the board, measured the voltage between positive and negative sides on the board itself and had the same zero volt. What I want to do now is trying to change the capacitors you are talking about in your posts and my question is where these capacitors are located in the board and where to buy such capacitors (have you an url or technical specs of these capacitors). Another question is : may i temporarely replace these capacitors by non smd ones just for checking.
Thanks for any other advise.
