PersianImmortal
5
Hi - just want to let you guys know that I've written a comprehensive <A HREF="http://www.tweaktown.com/document.php?dType=review&dId=324" target="_new">WinXP Guide</A> at Tweaktown.com. It's a walkthrough guide and fairly easy to follow. I've brought together all the known XP Performance tweaks in one guide.
Give it a try and post here if you have any questions/problems and I'll see what I can do :)
PS - Look out for more of my guides at Tweaktown.com :)
Toejam31
2,989
I think you did a great job ... thank you very much for all the hard work!
:smile:
By the way, I find that <A HREF="http://www.totalidea.de/framesetproducts.htm" target="_new">Tweak-XP</A> is an excellent addition for those users who are uncomfortable working in the Registry, and who want to quickly and easily optimize many aspects of the operating system.
Toejam31
<font color=red>First Rig:</font color=red> <A HREF="http://www.anandtech.com/mysystemrig.html?rigid=17935" target="_new"><font color=green>Toejam31's Devastating Dalek Destroyer</font color=green></A>
<font color=red>Second Rig:</font color=red> <A HREF="http://www.anandtech.com/mysystemrig.html?rigid=15942" target="_new"><font color=green>Toey's Dynamite DDR Duron</font color=green></A>
__________________________________________________________
<font color=purple>"Some push the envelope. Some just lick it. And some can't find the flap."</font color=purple>
PersianImmortal
5
Thanks. I'm not a big fan of TweakXP, but I've got links to TweakUI and XSetup at the end of my guide.
I may do a second part to this guide which goes into more utilities for XP tweaking.
<A HREF="http://www.tweaktown.com" target="_new">Tweaktown.com</A>
ejsmith2
3,228
TweakUI and Xsetup are good calls. A lot of people around here by using those.
Also, GTU (geforce tweak utility), NVrt (Nvidia refresh tool), and NVmax (Nvidia something-like-maximum =) are also good ones.
[Jedi mind trick] You LOVE Palladium. [/mind trick]
miahallen
572
Hey, just a side question for you Toejam31...I was checking out you Duron rig's specs, and noticed you have Logtech's dual optical mouse...How do you like it? I've been looking to get a new mouse and debating between this, or a standard optical. How do YOU like it?
Toejam31
2,989
Just my personal opinion?
I'm very satisfied with the mouse, and it is the best I've ever used. And since I like to play games <i>and</i> work in Photoshop at high resolutions, (correcting defects in images), I need comfort and high accuracy. This mouse has it all.
I went through quite a few different pointing devices until I finally tried the dual-optical. I knew that I didn't want yet another ball mouse, because I kept wearing them out, and I wanted to get away from the PS/2 port. I really wanted a cordless mouse, but I hated having to replace the batteries every couple of weeks. The lag with the cordless device was definitely <i>not</i> a good thing, even on a USB port. And keeping the cordless mouse synchronized with the radio receiver could sometimes be a real pain.
Then I found this dual-optical mouse, and I liked it so much that I bought two of them, one for each system. Of course, it still has a cord, but it's flexible enough (and long enough) that it's easy to arrange out-of-the-way. It's more comfortable than the cordless Logitech mouse with the single optical ... and it's beyond a doubt the most accurate mouse that I've ever used. Absolutely no lag, whatsoever.
With a regular optical mouse, or a cordless optical mouse, I could move the cursor back and forth in a small area with a rapid movement, and watch the pointer stall in the middle. With the dual-optical, even if I move the mouse as fast as possible, this doesn't happen.
The dual-optical and the Logitech drivers work just great in WinXP, (even with the Service Pack), if you were curious.
If I was in the market for a new mouse right now, I'd want to compare these three, and make a choice between them.
1.) The Microsoft Intellimouse Explorer 3.0,
2.) The Logitech dual-optical,
3.) Or the brand new Logitech MX500 and MX700 mice. The MX700 has the same specifications as the MX500, except that it is cordless, and comes with a recharging station/receiver, instead of running on regular alkaline batteries.
Toey
<A HREF="http://www.btvillarin.com/phpBB/index.php" target="_new"><b><font color=purple>BTVILLARIN.com</font color=purple></b></A> - <i><font color=orange>A better place to be</font color=orange></i>. :wink:
kdo2milger
176
I don't know why, but I was getting memory error screens non stop upon reboot and could not get any further into windows xp pro after adjusting the memory options. I had to reformat and install, repair would not correct memory disfunctions, other than that I used everything else, and worked out pretty good, especially the "timetodelaymenu" and "waittokillapps" option. Now things seem to be smoother and faster, it was noticable to the eye;)
<font color=red><b>We all love disassembling things to see how it works,
but who wants to put it back together again?
malfunc
Great tweak guide! The best for sure at the moment!
I had som trouble with this little part though:
Disable Balloon Tips and Force early grouping of similar tasks in taskbar
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced]
EnableBalloonTips=0 Turns off the yellow popup balloon tips.
TaskbarGroupSize=3 Dword value of the number of similar windows reached before grouped together.
I find the 'TaskbarGroupSize' thing to be very interesting and a must to test.. but I can't find that tag in my registry.. Is it possible to just add it? and how to?
Thanks again for a great tweak guide!
/ Claes
Toejam31
2,989
Here's how:
Scroll to the Advanced subkey, and open it by single-clicking, so that you can see the contents of the key (folder) in the right window pane.
Right-click in the right window pane, and chose "New - DWord Value".
Type in the name of the value, exactly as posted.
Right-click on the new value, and choose "Modify".
Specify the number assigned to the new entry under Value Data. Select Hexadecimal as the Base.
For "EnableBalloonTips", the Value Data is "0". (No quotes, either in the name or the Value Data.) For "TaskbarGroupSize", the Value Data is "3".
The Value Data displayed in the right window pane (under the "Data" column) for the new entries will look like "0x00000000(0)" and "0x00000003(3)" when you are finished.
Reboot for the changes to become functional.
Toejam31
