I couldn't seem to find exactly what I needed by searching the forums so I thought I'd post this.
My problem is simple, but I can't find a solution. I just swapped my parts into my View 71 ARGB Tower that I purchased a few days ago. Absolutely everything is connected fine and it looks amazing. The three TT fans that were already attached are spinning and doing their Rainbow pattern. The trouble is I can't figure out how to connect the RGB cable so I can control their color and pattern with Aura.
I have an ASUS Prime Z370-A II MOBO. The TT directions for the View 71 tell me to use the included +5V, 3-1 PIN Cable to attach it to the Thermaltake Fan/RGB controller that is in the case. The problem is the Aura RGB strip header is a 4 PIN and is labeled as 12V, G, R, B. There is no included cable or adapter that fits this pattern nor anything describing the different labeling for ASUS in the instructions. I looked for another place to connect the cable that TT suggests and for the life of me cannot find anywhere that fits the pattern and schema.
Should I have a different cable with a different PIN pattern to connect my MOBO to the Fan controller? Am I just completely missing where to connect the cable I do have (+5V, 3-1 PIN) to somewhere on the ASUS board?
I bought this hoping I could match all my colors with my GPU, Cooler, MOBO, etc.. Thanks for any help in advance!
