Review Corsair Dominator Platinum RGB 32GB DDR4-3600 C16 Review: Bright Lights, Speed City
abryant
Asst. Managing Editor
Staff member
May 16, 2016
184
19
18,685
More RGB, more performance. What else does Corsair’s latest Dominator Platinum kit have in store for us? Read more here.
THOMAS SODERSTROM
@Crashman
Thomas Soderstrom is a Senior Staff Editor at Tom's Hardware US. He tests and reviews cases, cooling, memory and motherboards.
Given that we don't have any memory that costs exactly the same price, your comment isn't very helpful either.
Ok. I will have patience.
Look here
All cards on the same line have the same price performance ratio, but that's useless to compare the cheapest product with the most expensive.
No card has exactly the same performance, or price, as you retardedly interpreted, but still is possible to tell that the RTX 2070 is better than the radeon VII .
Obviously, i didn't mean exactly the same price. Your comment is so stupid, that it can only be malicious or retarded.
Anyways, you will not understand. I'm wasting my time.
Look here
If this is what you'd meant to say I think you would have said it from the outset. Now, I see a chart for graphics card FPS and you'll go on to give me some explanation of how it can be applied to MB/s of file compression in 7-Zip or whatnot, but then you're talking about two different charts.
Please allow me to explain how the performance/price chart is useful, particularly to people who can do basic math in their heads. X product costs 10% more than Y product but only has 5% better performance, so it doesn't reach the same value score. You already know that if you're looking at a 10% increase on a $500 memory set, it's $50 that's getting you your 5% better performance from $550 spent. But if you're really smart you know that 10% better performance applies to the whole machine when memory is the bottleneck, and if it's a $2000 machine you're improving its performance by 5% for only a 2.5% increase in system cost. Suddenly that $50 looks like money well spent.
Since we can't guess what your machine costs, we're counting on the serious readers to do that math on their own. The easy chart is for casual readers, but it still shows average performance on the bottom two bars.
The next step for the hardcore reader would be to use application specific metrics. We only have four of those due to time. But those calculation are easy: 154 FPS is still 10% faster than 140 FPS, and 7:12 is still 10% faster than 8:00.
I hope this helps.
