Hi friends,
I recently grabbed a lightly used H100i for a good price and dropped it into my system. It was in a perfect condition at least for the looks of it. It seems though that the results are not what to be expected.
My system:
I have overclocked a i7 3770 non K using the +4 bin turbo overclock with additional bclk adjustment.
My 2 gaming profiles are:
a) 41 x 105 = 4.3 ghz. Manual Voltage at 1.26 volts, drops to 1.2 volts under full load due to Vdroop (LLC medium, 50%)
b) 41 x 107.4= 4.4 ghz. Manual voltage at 1.31 volts, drops to 1.28 volts under full load due to Vdroop (LLC high 75%)
Results using (a) profile:
Idle: Cpu package hovers at mid 30's after hours of usage, H100i Liquid temps stay at 31.5 C (+/- 1 C). Average Delta 5C. Ambient Temps now are around 20C.
Load:
Prime95 Small FFT 26.6 version, 3 cores hover at 70, second core hovers around 75C. H100i Liquid temps at 37.5 C. Delta almost 40 C !
Results using (b) profile:
Load:
Prime95 Small FFT 26.6 version, 3 cores hover at mid 70s, second core hovers around 85 C. H100i Liquid Temps at 41.5 C. Delta almost 45 C !
H100i: Pump is set at maximum speed, tops at 2200 rpm using 12 volts from cpu fan header. Fan profiles are set so that the fans will ramp up to maximum when liquid temps approach 40 C.
Case: 3 front intake 120mm fans, 1 120mm exhaust at the back. Set to spin at maximum when cpu temps touch 70C
Troubleshooting:
-Made sure the pump works
-Re-installed the block, re-applied thermal paste (Arctic MX 4), made sure the block is in tight contact with the cpu
-Added washers on the back plate (no difference)
The radiator nor the tubings never feel hot, maybe slightly warm, guess it's normal for 42 C max peak of liquid temps. I know Ivy is running hot but i expected 10 C less at least for profile (a) where voltage peaks 1.2 V under full load.
My thoughts, bad contact due to block deformation, bad integrated TIM of the cpu. My temps are not dangerous but they are not desirable for my likes. If anyone has any idea or i am missing something please jump on the discussion
My system:
Load:
Load:
Troubleshooting:
