I spilt a bit of water on my keyboard a few months ago. It worked fine at the time, next day several keys were dead - F6, 6, Y, H and B - all in a line.
I dried it out and months later there's no improvement.
I didn't notice any damage at the time, but I thought I'd try swapping in some new switches - for 6, Y H and B - not F6 as that was hidden by some other PCB and plastic.
After the new switches are in and the LEDs still work, and from what I can tell and test with a multi-meter there is still current going through the replaced switches.
I didn't swap the F6 key as I didn't realise it was broken, it was hidden by a plate which I've just removed and it looks like the PCB is damaged there.
Given this is a £180 keyboard which I can't replace right now I'd love to fix it.
Can anyone provide some ideas on what I should do next, or if the PCB holds any clues as to what I should do?
I've taken some pics and a video showing off the damage you can see here - View: https://imgur.com/a/5MGZwdL
N.B. The video is taken after I did some more cleaning. I've just ordered some more Iso as I ran out so I can clean it more thoroughly.
