Question Corsair rgb hub: 3pins argb to 4pins
Mar 3, 2025
Hi,
I recently bought 2 adapters 3 pins argb to 4pins to connect my corsair fans to the corsair rgb hub, but I think there is an issue with the adapters.
Here my setup to explain the issue. I have 3 corsairs fans: one with 4 pins rgb and the other two with 3pins argb.
If I plug the 4 pins fan in the first slot and the other two with the adapters on the second and third slot, the leds on the third fan doesn't work, no matter which cable I use.
Basically, the fan connected in the slot following the adapter doesn't light up.
Should I buy new adapters and if so which one?
I'm using corsair RS140 fans. I was told that the corsair rgb hub operates at 5v. I think I'm wrong when I say 4 pins rgb. I should rather say 4 pins corsair proprietary connector.
