Hello everyone
I have been having some weird issues for a good few months now. Randomly without warning, the USBs will drop out (such as audio interface and USB HDDs) and then come back again almost instantly. I also have random blue screens when I start the computer up and when I check it, the error is a "Kernel Power" issue. I also sometimes get an issue where the USB HDD/SD Card reader I'm trying to copy too will drop out and wont let me copy files. This requires a restart each time. After much research on the tinterwebs looking at power saving options (changing it to balanced and high performance etc), power options for when the USBs should sleep, updating drivers, re-seating components etc I came across a post that said it might be a PSU issue. So I broke out the handy dandy multi-meter and checked the voltages on the power supply and found them all to be above what they should be (above the 5% ATX spec threshold). Here are my results:
Power supply with just 2 hard drives and a SSD running (with a paperclip bridging the on pin so the power supply was on) testing from the main power cable:
3.3v pins = 3.69v
5v pins = 5.40v
12v pins = 12.86v
Computer on (tested from a molex plug):
These are all above the 5% that it should be but not massively. Do you think these slight discrepancies could be causing the problems that I have been having or do you think it might be a more sinister problem 🙁
PC Specs:
Intel 4790k Devils Canyon
Asus Maximus VII Ranger
nVidia GTX 1070
OCZ Stealth X Stream 2 600w PSU
16GB Patriot Intel Overclocking Masters DDR3 RAM
Cooler Master Hyper 212 Evo CPU Cooler
2 x Western Digital Black HDD 7200rpm
Samsung EVO 500gb SSD
2 x 200mm Coolermaster RGB Fans
1 x 140mm Cooler Master RGB Fan
3 x 120mm Cooler Master RGB Fans
Cooler master RGB Controller
USBs pluged in normally:
WD Free Agent GoFlex 2TB USB External HDD
Scarlett Solo v1 Audio Interface, Mic and Headphones
Corsair K95 RGB Keyboard
Roccat Kone AIMO Mouse
Monitor USB Hub with just Logitech C920 plugged into it.
USB Bluetooth dongle for controllers.
I think that's all the main stuff, please let me know if you need anything else!
Thanks a lot in advance everyone! Any help is very much appreciated!
All the best,
Will
3.3v pins = 3.69v
5v pins = 5.40v
12v pins = 12.86v
Idle: 5v = 5.43v 12v = 12.79v | Under load (Shadow of the tomb raider benchmark): 5v = 12.70v 12v = 5.46v |
PC Specs:
nVidia GTX 1070
All the best,
Will
